what you do is you connect everything together. using clamps and or zip ties. you will have to jump start your psu and give power to the pump and nothing else. you have to do a leak test for at least 24 hours
instructions how to jump start a psu
source
1st thing is first. Unless you plan on having a load full time on a jumped psu, only jump it for a short period ( 2-3 seconds max) at a time. Running a psu with no load can cause it to damage itself. Also please disconnect the psu before jumping it, and after finished. Toolds needed. 1- ATX PSU 2- Wire Strippers (or teeth, depending on lazyness) 3- Short length of wire (or 2 if you do the optional step) Its a 1 step process! Grab your psu, examine the atx connector itself, u'll notice a green wire with a black wire on either end of it. Take your length of wire, and use the wire strippers (or teeth) to strip a small section of cover off each end of the wire. Insert one bare end of this wire into the opening of the green lead on the atx connector, and the other end into any of the 2 black lead openings beside the green lead opening. This will jump the psu, and if it is plugged in (i suggest jumping first, then plugging it in), the psu will turn on (that is if its any good). Remember only run an unloaded psu for 2-3 seconds MAX! Notice the jump from the black and green wires. |
