Originally Posted by
ZytheEKS
Dimensional-Warping Molecular-Level-Thermologically-Balanced Carbon Nanotube Hexaduple Quad-Phase 17-Parallel-Dimension Quantum-Tunneling Space-Fabric Rift block, with its accompanying Anti-Gravity Einsteinium-alloyed Magnetorheological Sub-Zero Kelvin Thermal Interface Material would work better, but if you can't manage that definitely go with a liquid cooling loop. Air cooling simply won't due for high overclocks on high leakage chips like the piledriver CPUs.
My recommendation is the H2O-H220 kits from swiftech, or if you aren't going to be getting it for a while you could get the H320. They're the best way to get into watercooling short of the Raystorm kits, and I tend to advise against those for AMD CPUs because the
backplate on the AMD CPUs causes the XSPC Raystorm to bow, or so I've heard.
