1 - 4 of 4 Posts
New to water cooling here.<br><br>
Is it ok to watercool the CPU, Northbridge, & the GPU all in line with the same cooler?<br><br>
In other words go from the pump to the CPU to the NB to the GPU to the radiator and back to the pump?<br><br>
Thanks for any help!<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Yes, but first check the NB water block compability with your motherboard. I think <a href="http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=241&products_id=4042" target="_blank">Swiftech MCW30 Chipset</a> cooler is compatible with your motherboard.<br><br>
I suggest you to go<br><br>
rad > cpu > gpu > nb > res(t-line) > pump > rad
it isn't necessary to wc the chipset.<br />
<br />
<br />
go pump > rad > cpu > gpu > northbridge > pump
SNERP!!!
Just upgrade your Chipset cooler to a better air cooler.
1 - 4 of 4 Posts
