Originally Posted by adizz
CPU Block:Zalman ZM-WB4 GOLD CPU Water Block AMD K7 K8 AM2 Intel 478 LGA775-$29.99
Rad:Swiftech MCR220-QP-K-CL Quiet Power 240mm Radiator-$29.99
Chipset Block:Zalman NWB1 Northbridge Waterblock (3/8" barbs)-$24.99
Tubing:Swiftech 3/8" ID 1/2" OD High Quality PVC Vinyl Tubing - 1 foot-$0.99
Hose Clamp:3/8" OD Adjustable Plastic Hose Clamp (1/4" ID)-$0.99
Coolant:Cooler Master RL-ACL-NNUG-GP UV Green Aquagate NC-1 Non-Conductive Coolant-$19.99
Am I missing something??
all parts off svc.com(they ship internationally)
The Zalman CPU block isn't the best choice...I suggest the Apogee GTZ
A dual radiator is nice but if you are cooling your GPU as well, spend a bit more for the triple...
I don't think you need a NB block...a waste of money IMO...(others may disagree)
For the coolant, if you are on a tight budget, use PT Nuke and distilled water from your grocery store. This will save you a lot of money because shipping non-conductive fluid is quite heavy (around a pound I believe).
Are you missing a pump and a reservoir/T-line from your list..?
