Hi everyone!
Today I checked my system (I do it nearly on a daily basis) and, since I haven't done it in a while I decided to check it a bit "deeper". I noticed a little bit of sparkling coming from the fitting on the waterblock. It wasn't much, I couldn't see any clear sign of leaking and I have been using this system for months (4-5), I did though refill it a bit yesterday (only added some liquid due to the fact that the pump made some noises and when I opened it it pressurized). Anyway… I decided to take out some ear cleaners and see what was that sparkling (the sparkling itself was always there I think but I really wanted to check it out again) and to my surprise there was some… yellow/orange moisture???... or something like that. I'm curious if it's something normal after a few months or if it's a bad sign or something (and if it's dangerous). My temps are also quite strange, I have about 21 degrees in my house but coretemp reported temps varying from 14 degrees to 21 per core at the same time while I was using the computer not in load, haven't checked under load(My cpu is a 4930k, 6 cores).
Here are some pics:
Most of the moisture is on the paper below:
Sry about the dust.
Also, I checked the fittings on the radiator and they are a bit different… Not 100% clean but much less stuff.
Here are some pics:
Sry about the dust.
