1 - 4 of 4 Posts
I currently have a 4970k that overclocks to 4.9Ghz very easily with no voltage change, the only issue is heat, I'm sure I can push passed 4.9Ghz but it would require new cooling, my question is, is it worth the money for a closed loop water cooler for the CPU?
I mean how effective are they? My budget would be about $70 and I'm trying to figure out the price to performance sweet spot, Id hate to put out money for small gains, and I'm not sure if going from 4.0Ghz - 4.9Ghz is worth the $70 it may cost for a closed loop water system, although its almost a 1Ghz overclock...
from the videos i have seen ( ie linus tech tips) AIO kits arent really worth it. now if you mean going all out making all the tubing yourself that could be different.
In my experience AIO kits have a high failure rate and is a pain to get replaced but if you get the right one, they can last a long time and you will notice a temp difference whether u go AIO or custom but for a custom loop, is more configured to ur setup, plus depending on the parts, can last along time.
I have had my current setup without changing anything for about 2 years now (accept the odd clean out which is rare), I do add stuff to it though, plus the only spare part you need is a water pump.
1 - 4 of 4 Posts
