1 - 7 of 7 Posts
· The Computer Guy
I fill mine at high/full as I can get it.
· Unwilling Beta tester
Originally Posted by subliminally incorrect
more water= better thermals
Not true. More water = longer to heat up and cool down, nothing more.
So long as the level is well above your outlet port(s) you should be fine. Keep an eye on it for the first few days, then check again after a couple of weeks. The level will drop slightly as the small bubbles work their way out.
1 - 7 of 7 Posts
