1 - 10 of 10 Posts
Yes, after using ceramiuqe on the surface of my brand new AMD 89watt 4400(ccbwe stepping)I remove the clamps to pull waterblock and the block is glued so hard to the top of the chip that it pulls the cpu out of the still clamped socket.<br>
this has happend twice now and I am wondering how many more times I will luck out and not ruin this expensive cpu.<br>
How many times has this happend to others...Scary stuff
Try twisting it side to side gently while trying to lift it...
Reactions: Renfeld
ceramique ? Doesn't that like fix it to the heat sink?<br><br>
Yes spin and twist for a while then slowly slide off
Reactions: Renfeld
SNERP!!!
It isn't that big of a deal. Just expect it to happen and play nice <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Reactions: Renfeld
Ceramique is supposed to attach it....to prevent that from happenign use Arctic silver 5.
Excel Guru
Why did you use ceramique on a non-permanent setting...?
Reactions: Renfeld
Old school
The same thing happens when u lift the heatsink of an Asus A4L laptop, the cpu always comes along (P4). Done this about a hundred times and never went wrong. If you wonder why, I work as repair engineer at Asus.
Reactions: Renfeld
SNERP!!!
Ceramique isn't an adhesive guys...<br><br>
This can happen with AS5 too. It's just the way it goes sometimes. Take it easy and all will be fine.
Reactions: Renfeld
Ceramique is not permanent. Any compound can get baked on and cause this to happen.
Discussion Starter #10
Thank you all for the VERY helpfull replys <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br>
REPS FOR ALL
1 - 10 of 10 Posts
