Originally Posted by tylor360 Does that look like oatmeal to anyone else in here? -10 for the prettyness factor ![]() but I guess when you computer run at sub-zero temperatures you can show off with that ![]() |
Originally Posted by Omri i gotta really big question for ya... when are we going to see the chiller in action!? ![]() |
Originally Posted by PetrolHead Dude, don't insulate the pump. If you insualte the pump it'll melt because it can't dissipate any heat. |
Originally Posted by tuchan I hope you get temps like that, what are you using for thermal paste? the arctic ceramique. |
Originally Posted by wowza Hadn't planned on using anything, the dielectric grease and all that crap will be overwelming.. mabye the ceramique, or the stuff they use on the vapo kits. Edit: This is what i'm talking about Tuchan link |
Originally Posted by PetrolHead If you insulate too much of the pump it'll just melt the plastic. I'm going to be building a water chiller soon, i've just bought an FR85CL and i'm gonna get some R404a, it's a bit expensive so i might have to use 290 but it should hold -20c idle if it all goes to plan, then i might even try and build a cascade water chiller or i could convert it into a DD SS/C. I look forward to seeing your result's though. |
