1 - 14 of 14 Posts
Hi there,
Yesterday I put together my first custom water cooling loop, and today decided to fill it up. Once filling my reservoir up half way however, I attempted to power cycle it on and off in order to drain the res and refill. When I turned it on however, the pump physically did not 'intake' any water and the water level of the reservoir did not decrease. Can someone please help me as to why this is, is it a faulty pump? At first I thought it could be, but I have followed all necessary precautions and the pump has always had a extremely good reputation. Following that, my reservoir is also higher then my pump, and directly connected to it via a male to male fitting (i can take pictures if needed).
Please help as I really just want to get this water flowing and get back on my pc
thanks
+1 for picture. It could've been just a simple mistake of mixing the inlet and outlet.
It's hard to see, but if you look underneath the res - the arrow seem to suggest it's an outlet... ?
I don't know why they can't just use words "in and out" rather than symbols.
^ Right.
For a D5, you want the res connected to the middle port on the biggest side of the pump, and the outlet where you have the res connected now.
I just hope you haven't done any damage to the pump...
Discussion Starter · #11 ·
So in order to fix my problem I need to switch either the switch the reservoir or tube to the opposit port in which it is in? Guess I've now gotta drain the current liquid in my loop out then
Yes you will have to drain. Just reorient the pump so that the circle part is facing down and switch around the connections and you should be ok. The res should connect to the port in the middle of the square right next to the Alphacool logo, and the tube should go where the res is right now.
EDIT: Looking at it again there is an easier solution, just switch the res to the connection that is right next to it. That will solve the problem.
EDIT2: Same as what is said just below.
Simple mistake. :]
Ask more questions.
1 - 14 of 14 Posts
