cool vid...i got a little drunk from the shaking heh and couldn't really see the reservoir. but over all i got the point.
Originally Posted by Mygaffer ![]() Isn't 60-70C almost what a good air cooler can get? Is this typical of a water cooling setup? |
A barb is that shiny thing that is screwed into all the in's and out's of the water blocks and and radiator and res that the tubing go's over to connect the tubing with the blocks, and then the compression fitting goes over the tubing and screws into the screw threads on the barb with the tubing mashed between them.
