1 - 4 of 4 Posts
hi guys i just bought a bigwater 12cm liquid cooling system
hi guys i follow the instruction clearly but then i only got one tube is working the other one is not doing anything . how come ?
What do you mean you only have one tube working and the other one doesnt do anything?
Include a pic or something... Make shure your connections are tight, you are running the loop, Pump --> CPU --> Radiator --> Pump
thanks for ur comments bro but what u said is wrong . its pump to cpu and radiator to cpu . i got it works already ihih
1 - 4 of 4 Posts
