1 - 12 of 12 Posts
I just want to know if the part I have select to upgrade my Rasa kit are good. I mean, better than what i already have. All my tube are clouding and at some point, the white thing is peeling off the tube (My block is maybe full of gunk
). I want to change my pump since mine start to make quite alot of noise and it is annoying my self. I need a bay reservoir because I don't have the space in my case.
Ah, and for the barb. I have 7/16ID and it look like to be and "not so usual" size so I decide to change for 3/8ID / 1/2OD with rotary fitting. For the 45degree angle... it is because I have a hard turn to do and I think my tubing is kinking...
I have an important point to, I from Canada
and if you know other store than Dazmode and Ncix who are selling watercooling part, it would be apreciate (I know newegg is selling some part like Ncix).
So yes, waiting you opinions/suggestion/advice/etc.
I will also post picture of my rig before and after the upgrade... because I know you love picture
Before :
450
700
After : Look here
Thank you
Lee
It is pure distille water and it is the tubing that take the white color. The water in the reservoir is still crystal clear.
But, can someone tell me if the DDC 3.2 + the Koolance reservoir is a good choice?
I have read that EK add trouble few month/year ago but did their rotary fitting are reliable?
Thank you for your reply!
Lee
Discussion Starter #5
I have keep in mind that one day, I will maybe put my 6950 and an other
underwater in dual loop. I just don't have the money the willing to spend more on my computer that do everything I want (exept sandwich
Discussion Starter #6
I was looking in the dazmode store and I think I will swap the DDC pump and the reservoir for a D5 Vario + XSPC Reservoir for one D5. I will save around 80$ and if one day I what to have my GPU WC, I will have more money than I will probably change more part.
So yes.... the cost is around 220$ now. I'm expecting to get less noise from the D5 and it is what im looking for.
If someone just say I'm making a good decision, it will make my day
Thanks alot OCN.
Lee
Ninja edit : Sorry for the double post
Discussion Starter #8
And do you have some information about the Dazmode store? It is a reliable place to buy? Anyway, I'm buying with paypal but I don't want to have to mess with them if somethink went wrong?
Edit : Order send... Will post pic when everything will be home
One question, why did you choose UV blue tubing, but you're using blue code cathode lights? Why not use UV cold cathode lights?
Discussion Starter #12
I realize that I haven't post any pics of after my upgrade. It is because my picture was on my father camera and he always carry it in his backpack. That mean when he is out, the camera is out. It take around a month before I got the chance to upload my pics
So here I start :
Here is what was at in my mail
And now, the horror movie start
My block was worst that I was believing
The other side
Better now
Checking for leak after I have reassemble the block
Once mount, with new rotary fitting (loving those little thing)
Leak test, never enough of paper towel
Final result. I don't like the bottom fan, will take it of later
Same with flash
Now, surprise for my loyal
follower
Some Gentle Typhoon AP-15 to replace my rad fan (YateLoon Med)
I did some "Y" to connect the fan to the fan controller 2 by two
The process step
Hope you enjoy and I will make an update with the GT AP-15 install.
1 - 12 of 12 Posts
