1 - 4 of 4 Posts
Hey guys, I'm about to order my first watercooling loop and I'd like some feedback.
Here's the parts and the plan : http://imgur.com/a/hxaA1
I have a few concerns about how I would implement draining in the system and how can I make the loop look tight. I'm not so sure if a d5 can push the whole setup too. We are working with a phanteks enthoo primo for a case. Can you guys see any improvement I can do on part selection and placement?
I don't even like Linux
Seems like odd placement for res - even if it fits in there, it will make installing videocards difficult. It is better to have the case beforehand and double-check all the dimensions. As a general idea looks fine though. D5 will do just fine.
Hi,
you can use something like this to drain your loop later on
http://www.aquatuning.us/water-cooling/fittings/ball-valves/19018/koolance-ablasshahn-g1/4?c=6496
http://www.aquatuning.us/water-cooling/fittings/ball-valves/20256/alphacool-magnetventil-chrome?c=6496
1 - 4 of 4 Posts
