1 - 14 of 14 Posts
intel p4 3.2 ghz ht
idle temp 56 degrees
load temp 65 to 72 degrees.
got geforce 6600 graphic card.
plzzzz help!!!!!!!
using heatsink provided with processor.
using normal thermal compound.
dunno how much to apply.
will good quality thermal compnd help??
i have the one which is white in colour.
HELP!!!!!HELP
Administrator
Artic Silver 5 is quite good and will lower temps by about 5C or so. Are you sure the heatsink is placed correctly.
Originally Posted by santosh86
intel p4 3.2 ghz ht
plzzzz help!!!!!!!
HELP!!!!!HELP
quick fixes:
1) buy arctic silver 5
2) put about a dot the size of a bb on the center of the chip
3) don't spread it around, let the heatsink pressure do it for you
4) place the heatsink on without moving it around too much
5) BUY A NEW HEATSINK!!!!!
jk, do it, tell us if it helped...those pressy's are hot!!!
intel p4 3.2 ghz ht
plzzzz help!!!!!!!
I have exactly same configuration as you do, 3.2 p4 and 6600gt. Intel stock HS sucks and that temperature is pretty good for it. Put some 80mm fan around the case to help vent hot air works. Getting a air duct to feed cold air directly from out side of case works best. Try some new thermal compound or try to apply it again the right way. I have 7700AuCu and it idle at 36 and burn at 53
Discussion Starter · #8 ·
ventilation is no problem. already have 2 extra fans in my cabinet.
have to try some new thermal compound. could there be a defect in the processor or the motherboard????? just curious
Discussion Starter · #9 ·
Originally Posted by remote_username
if all of the obove dosent work then clearing the cmos seams to work
have to try some new thermal compound. could there be a defect in the processor or the motherboard????? just curious and just how do i clear the CMOS ???
does the sensor always show the correct temperature.
coz i tried almost every way to apply the compound...
Discussion Starter · #11 ·
Originally Posted by newbieocer
quick fixes:
Discussion Starter · #12 ·
Originally Posted by stevo3
get better airflow going around your system. the colder the air around your hsf, the colder your cpu. and pressies run hot but there is no excuse for them running that hot!! try reseating your hsf and reading the guide on applying thermal compound.
http://www.overclock.net/showthread.php?t=12419
You dont need to reply the same thing to 3 people!!
To clear your CMOS get your motherboard manual and it will show you the locaion of the CLEAR_CMOS jumper (or it might be called something similar, RESET CMOS or something, in my gigabyte it's clear_cmos)
Put a jumper on it. Turn your PC on, it wont power up but it will reset the BIOS settings.
Remove the jumper. Turn your PC on. It will say CMOS Reset press F1 to continue, or something similar. Press F1 (obviously)
Then check your temps.
I found after messing around with all my settings, my fan was running at about 1300 RPM insted of 2500 RPM which is normal for it. After clearing CMOS it was working okay again.
Good luck!
1 - 14 of 14 Posts
