1 - 5 of 5 Posts
Hey guys I'm going to start with water cooling very soon just need some help on the final product choices as i don't have the best with knowledge regarding water cooling.
Case will be my sig rig CM storm sniper black edition with a top 2x120mm radiator (still cant choose need help please)
I plan on CPU cooling only, Won't be adding video card onto it.
*I want to run Cpu 24/7 at 4.5ghz -5ghz mark*
I order all my parts from Pccasegear.
I need help with what radiator, tubes and fittings to use.
Was eyeballing off the following rads,
Please help me choose
http://www.pccasegear.com/index.php?...oducts_id=3978
http://www.pccasegear.com/index.php?...ducts_id=13102
http://www.pccasegear.com/index.php?...ducts_id=13082
Link to tubes and fittings, Please help me choose.
http://www.pccasegear.com/index.php?...th=207_160_853
http://www.pccasegear.com/index.php?..._300&vk_sort=1
TIM: Indigo Xtreme 1366
http://www.pccasegear.com/index.php?...ducts_id=13995
Pump: Laing D5
http://www.pccasegear.com/index.php?...ducts_id=15012
Reservoir: XSPC Acrylic Dual 5.25"
http://www.pccasegear.com/index.php?...ducts_id=14352
CPU Waterblock: EK-Supreme HF - Full Nickel
http://www.pccasegear.com/index.php?...ducts_id=13866
Coolant: CoolerMaster Thermal Conductivity Fluid
http://www.pccasegear.com/index.php?...oducts_id=2131
Thanks in advance.
I'd the XSPC RX radiator. I like your pump choice, the D5 is a great pump. You don't need a bay reservoir, XSPC sells an attachment for the D5 that replaces the stock top on the pump and incorporates a reservoir. This simplifies tubing and ensures that the reservoir is always feeding the pump.
Don't use coolant, it is a waste of money and sooner or later it will break down leaving gunk all through your loop. It is much better to simply use distilled water from the grocery store and either PT-Nuke or a silver kill coil.
Your links to the tubing and fittings didn't link to a specific item, so I'm going to suggest that you use 1/2" ID 3/4" OD tubing with matching compression fittings.
I like the idea that i can just have the pump in the 5.25" bay with the res, seems easier for me.
Pccasegear does not have that attachment you mentioned, not unless i missed it while looking.
Links for tubeing and fittings work on my end (just moved onto old laptop with no browser cache loaded and it loaded for me.)
1 - 5 of 5 Posts
