1 - 11 of 11 Posts
ok. so idk much about watercooling.. so i was wondering if any of you experts out there could help me.... i need to cool my cpu. and i would also like to cool my northbridge.. i dont really have a budget limit. but it'd be nice if it werent that expensive
I would suggest a 360 rad, 655 vario pump, micro res (or bay res if you prefer). I like my heatkiller cpu block, but there are lots of other choices.
Here is what you want:
MCP355
XSPC Reservoir Top for Laing DDC (MCP355)
EK Supreme HF Full Nickel - Best CPU block on the market
1/2" ID 3/4" OD tubing - Good for preventing kinks and getting the highest flow rates
1/2" ID Barbed fittings
XSPC RX240 rad - good rad for low speed fans
You don't really need to cool your northbridge anymore, now that the memory controller has been removed from it and added to the CPU.
I very much agree with the above post. I like Primochill tubing, and always just use distilled water and PT_Nuke. Like charliehorse said, skip the NB cooling, but you could get a full-cover block for your graphics card.
I just built my first WC rig myself and here is what I did:
Danger Den TDX CPU block (was on sale and cheaper than EK but I really liked the EK)
Primochill 1/2" x 3/4" tubing
Bitspower 1/2" barbs
Swiftech MCP-320 rad (probably should have gone XSPC / Feser but I kept seeing this listed as best cheap cooling rad my second rad is a TFC (Feser))
Swiftech MCP655 pump. I was planning on adding a GPU block and second rad (which I did this week) so I wanted higher flow rates. For CPU only it is overkill. Go with MCP355 and save some $$.
I spent $178.00US not counting fans on my CPU only loop. Warning, it is expensive and addictive
Yes. You'll need to upgrade your radiator power to something like a GTX 360 with medium speed fans or by adding another low performance 240mm.
For the GPU water block get a EK FC480 GTX Nickel - Plexi. It's one of the best performing water blocks on the market and it look awesome.
Here is a picture of two of them in SLI:
Credit for PIC @ USFORCES
And yes, I use this picture waay too much.
Green LEDs installed in the 5mm LED holes.
The XSPC Rasa waterblock is ~ $20 cheaper than the EK Supreme, and performs within 1C at load. If you're budget conscious, the Rasa is a better choice than the Supreme.
Village Idiot
XSPC RX or Swiftech MCR 360 rad
Swiftech MCP355 + XSPC top or DD CPX-Pro
Ek Supreme HF or XSPC Rasa
Swiftech MC-Res
7/16" ID tubing
Skip the motherboard cooling, it's a total waste.
Originally Posted by pewpewlazer View Post
Ek Supreme or XSPC Rasa
You mean the EK Supreme HF. The plain Supreme is 4C worse than any other high end block. (Rasa, XT, HF, 360)
And I agree. Motherboard cooling is pointless.
Village Idiot
Good catch. Yes I meant the HF. Used to just calling it the Supreme with the HF being implied.
1 - 11 of 11 Posts
