Hey guys. I'm buying everything for my wc set up tomorrow I just wanna make sure I have everything. Please help!
xspc rx360
xspc rx120
ek supreme hf - nickle
ek-fc580 gtx waterblock (I will SLI in a few months. Should I get it with the optional SLI fitting? Whats that exactly?) Or I was thinking of going with the DD gtx580.
Koolance RP-452X2 Dual 5.25" Reservoir with 180-Degree Connector for RP-452X2180-Degree Connector
2 Swiftech MCP655 D5 Pumps
4 Scythe GentleTyphoon D1225C12B5AP-15 120mm Case Fans
Bitspower G1/4" 45 degree 1/2" x6 (metal barbs or compression fittings?)
Bitspower G1/4" strait 1/2" x 4 (same as before barbs or compression?)
(anything else I need when it comes to the barbs?)
Tubes and Chemicals
Fan Controller (not sure which one yet)
Anything I'm missing?
xspc rx360
xspc rx120
Tubes and Chemicals
