1 - 3 of 3 Posts
I just bought a 2x120 MCR-X20 from swiftech i would like to cool my cpu which is an amd 8150 and a nvidia gtx570 will this radiator be enough? Or will I have to add another to the loop?
What case are you using?
I would add another 240 if you have room but, I have no idea how strong that pump is.
pump specs
Max. nominal head (@12 V)
14.7 ft (4.4m)
Max nom. discharge (@12V)
~ 4.75 GPM (17.5 LPM)
Maximum pressure
22 PSI (1.5 BAR)
im using a corsair c70
1 - 3 of 3 Posts
