Wc sketchup
819 5
Yo guys.
Tomorrow im getting my wc parts.
I made a sketchup for my setup.
(Pomp > Radiator > Cpu > Reservoir > back to pump)
Please rate it, and dont complain about my sketchupskills
1 - 6 of 6 Posts
Make sure your reservoir feeds into your pump inlet and that your pump pushes into your radiator. You'll want the reservoir above the pump so water is forced into the inlet by gravity.
Other than that
Glad to see you're getting rid of that bigwater system.
Other than that
Ye , the outlet is going to the RAd, and the reservoir is connected with the inlet
Thanks m8
1 - 6 of 6 Posts
