http://sincitiessin.imgur.com/ this is my current wc set up, it is a bit messy but im working on that
So far im running it in the loop of
res>pump>240>gpu>240>res
the pump is the mcp355, now im hearing that i need a head for this, but there are so many so im wondering what people are using and what experiences people have with this.
As well i plan to sli wc my 480 and get a koolance CPU-370 cpu block, so i also need to know will the set up of
res>pump>240>gpu>240>cpu>res be a good set up for over all loop temps?
because im buying a second 480 and 2 water blocks (cpu/gpu) please remember that new pumps are out of the question if one pump with a head is not enough it may be acceptable to get another 355 or a 350 pump
(also the cpu block will be put in a while before the second gpu)
