About a year and a half ago (2 years?) I started this project, and failed. Miserably. Then I tried again, and failed again. Miserably. So this is take 3 of a project I've been wanting to finish for a long long time. I hope for this to obviously be successful and much nicer and professional looking than all my previous half assed attempts. I would've started this a while ago, but money was an issue.. and still is.
I hope to use better components than planned before, do things CORRECTLY and in the correct order
The plan.. to modify an Antec 300 case to fit an xbox 360 inside and watercooling equipment. And hopefully make it look pretty as well
Hardware used:
Antec 300 case
XSPC Xbox 360 CPU/GPU copper waterblock
3/8" ID x 1/2" OD compression fittings from eBay
Koolance 3/8" ID x 1/2" GREEN tubing
Black Ice GTX 240 Radiator
Swiftech MCP350 pump
Swiftech MCRES Micro Revision 2 reservoir
Lamptron FC4 fan controller, LEDs modded to green
Xbox 360
Project updates!
Modding PC power supply
OCZ Power supply finished and working!
New DVD drive cable, soldering and sleeving
Making a blank I/O Plate + led testing
240 rad grill + green led fans + radiator mounted
PCI cover plate made
Reset + power button sleeving, DVD drive mounting, cable management hole
Sync button mounted, modding front panel usb + fan controller LEDs
Slow speed ahead captain.. HDMI + A/V port cut
Ethernet + USB pots cut, I/O plate "done"
I have chosen metallic black + green for the color scheme. return
return
return
