I'm watercooling my new build, you can see the build thread here: http://www.overclock.net/t/1363139/help-an-old-member-new-rig-1200
I just need some help clearing my 2 loops with you guys, these are the parts I've selected.
I'm having 2 loops, one is dedicated to the CPU/RAM. The 2nd is dedicated to the GPU only.
Res: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_299&products_id=20412
Pumps x2: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_201&products_id=22586
Rad x2: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_297_922&products_id=15847
CPU: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_878_879&products_id=19206
GPU: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_878_880&products_id=20594
RAM: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_878_881&products_id=22050
Using this guide, I plan on fitting the 2 240 mm rads: http://www.youtube.com/watch?feature=player_embedded&v=vwgVA6_xIis
I was going to have one pump and one rad dedicated to the CPU + RAM.
Pump--> Res --> Rad--> CPU --> RAM --> Pump
and then the 2nd loop
Pump2 --> Res2 --> Rad2 --> GPU --> Pump2
I don't really have a budget per say. I don't want to spend $1000, but I'll be buying things as I'm paying off the rest of my build.
Things I really need your help on:
Tubing - no idea
GPU - I need a 7970 or a 7950 (Either will do) that will fit a waterblock. I absolutely want the GPU watercooled so this is a must!
Barbs, what are those? - no idea either
Fans? Must be quiet, trying to do a "as silent as possible" build.
I'm going with the res because I think it would be the best choice for my case. This way I can have 2 loops running in parallel (I think), and I don't have to fidget with finding separate res and pump locations.
This is my FIRST time watercooling, please point out if I've gone full ******. Suggestions are more than welcomed, especially for the GPU!
Tubing - no idea
