1 - 11 of 11 Posts
How much you guys think this is worth thanks
Sata or IDE?
Green, Blue, or Black?
Originally Posted by rpm666
Sata or IDE?
Says Sata II....
I would say $45 shipped. They're like $60 or so new.
Originally Posted by Em1nenceFr0nt
Says Sata II....
Woops.
Woops.
Already ! Arlington. I just moved to SoCal from McKinney . . .
Hookem'
Hookem'
TxTech Alum, easy with those little horns
Rifle, can you fill us in with additional specs? Model number etc?
Discussion Starter #9
they're good drives. Problem is 500GB is probably on the low end as far as "perception"..
personally, I wouldn't keep more than 100GB on a single drive.
But for RAID setups, 500Gs work really well so if you had another one, you'd prolly get $125 for the pair as a mirrored set.
1 - 11 of 11 Posts
