1 - 10 of 10 Posts
What should I get?
2x WD VELOCIRAPTOR 10k rpm or 1x Intel X25M
I can only afford 1 piece or 1 set for raid 0.
In terms of performance SSD win over a lot or can't tell at all?
Stable or not is not an issue as it's for downloaded movies & songs only
Originally Posted by LoneWolf View Post
What should I get?
If it's only for data like you mentioned I would just get a 1TB WD Caviar Black or Samsung Spinpoint F3.
For Data, the F3s are what to get.
An SSD is best as an OS/programs drive.
Performance, SSD hands down.
Theres things SSDs offer that HDDs could never achieve, 0.1ms response times for example and burst speeds. The X25-Ms have burst speeds that exceed 2500mb/s vs 335 from a 600GB VelociRaptor.
http://www.legitreviews.com/article/1307/4/
That helps...
Just saying that I wanna get something that does all. OS & DATA storage...
In short is 10k HDD 2x raid 0 = 1x SSD???
Most people use an SSD for the OS and commonly used programs and a mechanical HD for the media. An SSD really wont have enough room for your media. Instead of a the VRs take a look at the WD 640 blacks - in raid 0 they have equal or slightly better read/writes. The VRs have slightly better access times but cannot compare tot he 0.1 ms time of an SSD.
Originally Posted by lsudvm View Post
if its for media then you dont need an ssd fo that. also dont want raid 0 since if a drive fails then your data is lost. get a couple of 2 tb drives instead - use for one backup.
not if you do raid0+1
1 - 10 of 10 Posts
