Originally Posted by andy8125 Evertime I OC it, it becomes less and less stable at higher speeds. It's not even that stable at 2.64 at 1.600 Volts...... Can you tell whats wrong? |
Originally Posted by archer_456 The bad new is that, IMO, most VIA based mobo's do not OC stable very well. What kind of stability problems are you having, reboots, windows freezing, BSOD? |
Originally Posted by andy8125 windows freezing BTW what's BSOD? |
Originally Posted by archer_456 BSOD = "Blus Screen Of Death" My mind has come to complete blank at the moment, LOL What do you have RAM set at? freq and voltage Have you made sure you locked the AGP/PCI frequencies at 66/33? |
Originally Posted by adas123 in that case, get a better mobo because if u cant change the voltages in the ram and agp stuff, u wont be able to get such a great OC so mayb go for a asus or abit |
Originally Posted by adas123 ok...sooorrrryyy..my bad. then what else can u adjust in your bios? mem timings, feq, and are you sure there is no pci lock |
Originally Posted by andy8125 The Mobo Bios doesn't give the option of those 2 frequencies... It only gives the CPU host. |
