1 - 12 of 12 Posts
Ok here's the deal... Yesterday i opned everest ultimate just for a check up and i noticed the my core speed and multi keeps changing.
For example im running at x11 multi and it keeps going to x6 back and forth... and from 3Ghz it goes to 1.4 or something... Kinda weird never seen this before. Anyone got any idea why it does that?
I tried resetting my bios to default stock speeds etc but it still does it
Originally Posted by lothar View Post
What for? SpeedStep is very good in saving energy...
Save Our Planet!
BTW. Every newbie keeps asking about the same
It can cause instability in a rig...
Check and see if your Bios reset header pins are loose. If so, your battery has leaked and you'll have to resolder the pins from the bottom side of the mobo.
This happened to on one of my Gigabyte boards and caused the exact same problems.
1 - 12 of 12 Posts
