1 - 20 of 31 Posts
This is not related to my gaming rig or really an OC question but I have a weird issue with what I call my laptop replacement PC. I purchased a used Dell Optiplex 990 ($99) a few years ago and swapped out the HD for a SSD. It ran very well but would run out of ram. Later I upgraded to 16GB and around the same time replaced the i5 with an i7-2600S (max it will support).
I started to get random lag issues at some point a few months ago (I thought it maybe related to a Windows update). The solution was always to reboot and at first I just thought it was Chrome (I tend to keep a lot of tabs open on forums etc.).
I did all kinds of troubleshooting and could not isolate to a driver program or service. I followed some YouTube antilag setting recommendations but nothing seems to prevent it from cropping back up.
Recently I discovered (on a fluke) that I do not even have to restart the OS, I can simply hibernate and resume within a few seconds and the lag will be gone again for several days. I have done this 2x this week and each time it resolved the lag. This kind of makes me think it is hardware related but not sure. I runs perfectly fine between reboots/hybernation.
I have checked temps etc. and nothing that reports in the system is out of spec or even over 45 idle 80 full load.
PC is only used for email, printing, scanning and forums etc. I thought about putting old i5 back in to see if it is either cpu or power issue (maybe this MB isnt really rated for it?).
Any thoughts?
TIA
Any thoughts?
TIA
Such thoughts they are very expensive.
Operating system management this starts from a PRO version of an operating system. (Retail box this is even better).
antilag setting recommendations ? There is no such a thing.
YouTube this is 100% full of garbage.
  • Wow
Reactions: mongoled
My point was I do not believe it is related to any settings etc. I may do a full reinstall but not sure it is really worth it at this point since could be hardware and I do plan an upgrade soon. I have gotten a lot of mileage out of this $99 PC (which included W7/10 and Office 2013) with a few additional upgrades I still have under $200 in it and it has been running 24/7 since 2017.
Device name OptiPlex-990
Processor Intel(R) Core(TM) i7-2600S CPU @ 2.80GHz 2.80 GHz
Installed RAM 16.0 GB (15.9 GB usable)
System type 64-bit operating system, x64-based processor
Check your task manager after enabling handle count column under details. I’ve seen handle leaks from programs that leave open handles often millions, after a few days that cause this exact problem.
Thanks, I enabled this field and will check it the next time the issue shows up! Funny thing is it sometimes it starts with missed keys when typing. Once it gets bad it is real noticeable in mouse movement, missed keys, audio hiccup's etc.
Turtle Rig Fan
I had issues like this on my last system that were resolved with a fresh windows install. I would start there before spending too much time on it
Reactions: sonixmon
More ram and faster CPU, you are increasing the heat output. Is it thermal throttling in any way ? Plug the fan back in ?
professional curmudgeon
Any thoughts?
TIA
^that.
i would also suggest looking at the bios and see if anything "looks weird" you have swapped the HD/SSD (ports?) and cpu. it should be fine but. . .i'd check for giggles.
It is probably one of the software that is running in the background with a bad memory leak, not releasing any unused allocated memory, until you do a restart or hibernate.
Reactions: noxious89123
How did you test this?
I found that weird issue with Nahimicservice.exe (in the other thread) by simply going through the list of running services and stopping them one by one and retesting for the issue.
Could be worth playing with Safe Mode to see if that eliminates the problem, as it would atleast give you an indication that it's a driver / software issue, rather than failing hardware.
Discussion Starter · #12 ·
I have eliminated heat on everything that has sensors (CPU, MB etc) but this is limited in this OEM PC. Also if I hibernate and instantly resume it is gone 1-2 days (actually going on 3 at this point). It could be VRM or something with no reading but thats a quick recovery?
^that.
Yes Bios is very basic in this and was updated but its an older model so I believe no more updates (will check again for grins).
I thought this too but hibernate resume reloads the memory from disk as is (I believe). That is what has me perplexed. I havent tried standby but may.
I closed all open apps and watched task manager, nothing spikes cpu, I just get the typical interrupt message in TM so there is something causing a hang on the CPU. Also I do not even see that service in my list of services.
Posts removed. Please play nice with each other. Being condescending is not necessary to get a point across.
Thank you. I know this seems a noob question to some and I don't care to qualify my PC experience (not worth it and I don't care what anyone thinks) but it has been an intermittent thorn in my side for a few months and thought it was a Win update that may have caused it. Though I always custom build my PC's I needed a replacement laptop for 24/7 use and no longer needed it to be mobile so I decided to get a small prebuilt low wattage etc. My plan is to get one of the newer nicer more custom mini PC's but I have to wait for the market to settle down so I am trying to get another year (hopefully) out of this. Probably will just reinstall but not having some of the old work software is holding me back.
Appreciate all the positive suggestions, kind of waiting for it to happen again so I can check Handles (so far max is 45k for Dropbox but it is not climbing). I will also kill services this time individually that was another good suggestion.
Discussion Starter · #13 ·
Started to creep back in today, mouse lag and youtube A/V stutter. Tried to kill all services that system will let me, no noticeable change. Killed all programs etc. no change. I tried standby this time (for 2 seconds) and issue gone again. I guess it is not the end of the world if I deal with that just annoying and why 2+ days to start up again. I did this just before 10 pm so I will note the next time this happens as well...
If there wasn’t a program with a ton of open handles, it could also be a DPC latency problem. You could try downloading this tool and starting it the next time it happens.
This tool will tell you if there is a specific driver that is taking too long to handle interrupt requests or process information. It also gives you an average response time which is useful. Good luck sir!
Sent from my iPhone using Tapatalk
Hmm.
Might not do anything, but maybe worth a shot. Next time it lags out, hit Win+Ctrl+Shift+B. This combo will restart your graphics driver. You'll hear a beep and the screen will flicker black for a second, and should then return to normal.
+1 for LatencyMon. I've used it before, but I can't remember why.
Discussion Starter · #16 ·
Hmm.
I will try that combo next time it happens again for sure.
I have run Latency Mon but it has really been inconclusive so far. While the issue isnt happening it does have higher than normal latency (but it isn't a gaming PC etc.). When the issue is happening Latency Mon is all over the place, reporting different drivers etc. I will have to try it again and look at DPC counts, but running it now it is showing USBPort.sys. One thing that kind of dawned on me is I am using an older cheap LED backlit keyboard on this PC. It used to use it for gaiming years ago but it has the occasional missed key. Not very often but it got me thinking, this is one of the symptom's when the problem starts along with mouse hickups. Obviously going to standby or Hibernate turns the keyboard off, maybe it is the culprit My kid has the only other non gaming KB I have so I may snag that and try it next time. I will also pull the USB and reset kb when it happens. Probably stupid that I didn't think of that before, have to wait a few days I guess...
Thanks guys.
Discussion Starter · #17 ·
Several windows updates that required reboots delayed my testing but did help prove it is a time based issue. No issues all week with the two reboots. It started again this morning and I tried the Win+Ctrl+Shift+B to reset video and that did not make a difference. Checked latency mon again and it was spiking a lot. I did a standby for 2-3 seconds and resumed PC and the spikes were gone. It always seems to be CPU 0 but it is probably the default cpu for tasks I assume. I checked in bios about controlling active cpus but the only options are all, 1 & 2 (check boxes). Not sure how that works with 4 so I decided to turn off Hyper Threading instead. So now the waiting game to see if it comes back. If it returns I will throw the i5 CPU back in and see what it does.
I am still looking at replacement options but it is not a great time to buy anything. Re-installing is still an option but to me it seems more hardware related.
Here are screenshots of LM, Wdf01000.sys lag spiking to 171ms! From my research this isn't the culprit but the artifact as it handles hardware level communication.
LatencyMon with issue:
Rectangle Font Water Circle Parallel
After brief standby same programs running (10GB in use).
Rectangle Font Parallel Screenshot Circle
With HT disabled, highest peak after 20 mins is USBPort.sys at 7ms. Not good for audio production (but I do not use this PC for that) and no noticeable lag etc. will see if this makes a difference in a few days.
Rectangle Font Parallel Pattern Circle
Hmm, Googling Wdf01000.sys does show that it can be related to "incompatible drivers or faulty hardware". Could be a corrupt driver somewhere.
Difficult problem to pin down for sure. I think a Windows reinstall would be my next move, but I can appreciate that can be a massive PITA. It would help rule out a software side problem though.
Discussion Starter · #19 ·
Yea I am really thinking hardware because dont think a quick standby would likely fix a driver issue. I am in the waiting game again after turning off Hyper Threading. I haven't seen any performance hits from doing this either so if it works I will leave it. If not I will try the i5 cpu again and see if that makes a difference.
Thanks!
Does slightly increasing SOC voltage make a difference?
1 - 20 of 31 Posts
