I was downloading the audigy SB EAX stuff from the cd that came with my sound card, the SB EAX. This sound card and the programs were orginally installed in my old computer. I moved the soundcard to my other computer and it worked fine without the software and drivers but i wanted to make sure i had everything anyway. During the final part of the installation around 97% completion a blue screen said that windows has encountered an error and needs to close or restart. So i restart my computer and it goes through start up before windows then "NTLDS"(i think those are the letters) is not found and windows needs to restart press ctrl alt del. I can get into my bios but i have no clue what do about this. When i restart my computer it goes through the same thing and back to the NTLDS(i will double check these letters).
THANKS FOR ANYHELP AT ALL, even if you just know what the problem is that would be helpful. I just want my computer back to normal.
