1 - 4 of 4 Posts
A little while ago the fuse box on my house was tripped by my mums now dead iron.... i was watching a DVD wen it happened on my computer, so it shut down.
When i booted it back up i could not get any sound, get music to play (even from iTunes or a memory stick), or a DVD to play...(but the discs are recognised that they are there)
So i was wondering wat people think could be wrong?
could it be that my sound card has died?
Re-install drivers for your SupremeFX II audio card
Well, you could take out the sound card, turn on the on-board sound and see if it works. If so, then more than likely the sound card somehow managed to get damaged.
^^^But yeh, uninstalling and reinstalling would be the first thing to do.
im goin to try that... thanks
but one thing which annoys me is that wen i did try and listen to music (to test the sound) the song doesnt play, the bar (slider that says how far into the sing u are, just in case my description was a bit bad) doesnt move at all...?
1 - 4 of 4 Posts
