Hi all, i currently own a thermal take view 27 case (https://www.google.com/url?sa=i&rct...aw0zqq22fFjAPdvIAqi79pZs&ust=1533587775099225). The case was brought before i had watercooling mind, however after i purchased my new cpu and gpu a while back i decided to get into water cooling.
Now here is the fun part, I started watercooling only the cpu with a 240mm slim rad, but now i have introduced my gpu into the loop i purchased a 360mm rad.
So my current setup (yes i know its strange its for testing and was curious and id like your opinions also) I currently have the 360mm rad on the front of the case with 6 fans push and pull config.
But then i also have the 240mm radiator just on the bottom of the case above the psu/hdd's compartment (sorry no camera as mobile phone got smashed by accident recently, so you will have to look at online pictures from link and hopefully understand where i mean)
Now i understand having the 240mm just on the bottom of the case is not getting any clean airflow, so would having this radiator in the case in essence be warming up my loop more than just having the 360mm? or just because of the adding cooling surface area will it better with it there?
I know this is a strange one, i was curious to see, i will be upgrading my case eventually to something more suitable.
Any thoughts?
Any thoughts?
