Originally Posted by Thumper
Looks like a good system, how come you went 8xx series not 9xx?
Hard to see the case in the picture, but it's looks green
I was toying with the E-Premium before having to re-allocate the $70 between it and the regular Premium.
Well no reason really other then I got a good deal on it plus its an engineering sample, I did get both series though 820 & 920, just running the ES fro now. And the case is black I just took a pic of the gutts(purdy colors) LOL
Tell me how the board does, as I am going to buying one soon.
First off mine was good out of the box, no DOA here.
PRO's: Well I like the way it is setup, theres room to pull the ram while the typhoon is on and in the case(my other system was cramped) Has a realy nice bios(compared to what Im use too) It supports just about any 775 socket CPU. Has plenty of case fan ports, its just plain nice IMO.
Con's: This board is meant for sata users not pata and such. I originaly ran 2 ATA 133 drives, 2 rom and dvd drives. In order to get the system to detect my optical and my master drive I had to plug them into the same master controller(talk about a pain because my rom drive is at the top of a 7 bay case and the HDD is at the bottom. Once this is done I had no problems however in the event that Id have to do a fresh install, I wouldnt be able to hookup my backup drive just yet.
Also since this system just booted right up to my current harddrive with out a repair or fresh install, iI think its runnign a little slow on post and shut down, Im hoping that doing a fresh install soon will cure this problem. Thats about it so far, I havent realy messed with anything else just been run bench's and such.
Im not realy much on writing a review on this PC stuff just yet, maybe when I get some more time on it Ill post more info.
