1 - 7 of 7 Posts
Hi all, looking for a laptop. I'll start with the general format:
What is your maximum budget?
-$1200 would be pushing it, if it does go this high I'd like something very quality.
What country are you in?
-USA
What will be the uses of this laptop?
-Everything really:
-Would like an amazing keyboard as I plan to write a bunch
-Decent graphics as I'd like to play some games. Nothing new, more like morrowind and some of the lighter 2D stuff from Steam. LOL, maybe some upcoming MMOs.
Do you have brand loyalty or care which brands we select for you?
-generally don't care for apple, as I would need to install a different OS immediately
What screen size do you require?
14" max. this needs to be somewhat portable/lightweight
What screen resolution do you require?
-something modern, nothing crappy
Are you looking to buy NEW or would refurbished/recertified/used be okay?
-I guess I could consider refurbished, prefer new
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet)
-6+ hours, hopefully more
What games would you like to play with your laptop? And on what settings?
-LOL, morrowind, light 2d games, nothing too graphic intensive but I would like power if I needed it.
What operating system do you need? (if any)
-doesn't matter
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.)
-I would like this to be as thin and robust as possible, given the other requirements are met
How much hard drive space do you need?
-Planning on installing a 256GB SSD anyways
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.)
-HDMI out would be nice
Is there anything else we need to know?
-The Lenovo T430u would have been perfect if the resolution wasn't so horribad.
-Considering the T430s with the extended battery, the screen gets low reviews though and while the HD4000 would suffice, seemed like I should wait till Haswel
-The Gigabyte U2442N was a contender, but I can't find one anywhere.
Thanks all! I'm just ignorant of what is currently out there and what is coming soon. I'm thinking I just might wait till Haswell for the vastly improved graphics and not worry about a discrete GPu, but I dunno.
Hence the $1200 if it meets all the requirements...
Also I should add that through my friend I get a 25% discount through lenovo, in that case would it be worth it for the t430s (1600x900)? Would the discount offset a resale value enough that a haswell notebook could be feasible once released?
-USA
-Everything really:
-doesn't matter
For what you are wanting to use this laptop for, I suggest the Alienware M11x R2. You can pick one up very cheap.
· Laptop Enthusiast
No. Anything with a budget under $1,500 shouldn't be answered with anything related to Alienware. I own one. Nuff sed.
The Lenovo Y580 is by far the best option here.
i7
660M
8GB RAM
1366x768
15" screen
Around $850. So far it's been the best buy you can manage.
· Ever Forward.
Lenovo y400 is worth a look
As is the T430s, factor in your 25% discount, that puts it around $1200; and if you can use the discount coupon code on top of the 25%, thats even less.
1 - 7 of 7 Posts
