1 - 20 of 31 Posts
I was just playing crysis, and overclocking. I only oced the memory but 100mhz, so it was at 1200, and I go into msi afterburner and my gpu was at 104ish!
No warning or anything!
Discussion Starter #6
Thats weird. When on stock clocks its only at 67ish. Why would a 100mhz memory overclock make it so high? I'm not sure how I would go about mounting this fan either.
either buy a fan with those screw thingies or use zipties.
Discussion Starter #8
Like right under where the fan is now? How would I zip tie it to that? And upon further playing it reached 77.
1 sec, i'll take a picture.
damn it. t-mobile is complete ass. i can't even text the pic. i can't post it as all i have is a phone, but here is a pic, i circled where the mount is, it fits 120mm if i'm not mistaken:
just fit zip-ties around the fan's screw holes and through the mounting holes on the case. worked like a charm.
Or you could screw it into the case like its designed.
i didn't have any screws that fit, so i used zipties. worked just as good.
Lol. So right there then. I'll put an old san ace I have lying around in there.
you'll be pleasantly surprised
It's on my carpeted floor, so not too sure how well that will work.
try suspending it with books under the feet of the case.
1 - 20 of 31 Posts
