I "m not so good at debugging stuff like this i kinda need a bit of help to prevent it again
Version=1
EventType=BlueScreen
EventTime=130063022243904617
ReportType=4
Consent=1
UploadTime=130063022245006620
ReportIdentifier=6adf63f0-7f94-11e2-86a0-c86000da5b72
IntegratorReportIdentifier=022513-12370-01
Response.type=4
Response.AnalysisBucket=X64_0x124_AuthenticAMD_PROCESSOR_CACHE
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.1
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
UI[2]=C:\Windows\system32\wer.dll
UI[3]=Windows has recovered from an unexpected shutdown
UI[4]=Windows can check online for a solution to the problem.
UI[5]=&Check for solution
UI[6]=&Check later
UI[7]=Cancel
UI[8]=Windows has recovered from an unexpected shutdown
UI[9]=A problem caused Windows to stop working correctly. Windows will notify you if a solution is available.
UI[10]=Close
Sec[0].Key=BCCode
Sec[0].Value=124
Sec[1].Key=BCP1
Sec[1].Value=0000000000000000
Sec[2].Key=BCP2
Sec[2].Value=FFFFFA80076E7028
Sec[3].Key=BCP3
Sec[3].Value=00000000B636A000
Sec[4].Key=BCP4
Sec[4].Value=00000000E7000135
Sec[5].Key=OS Version
Sec[5].Value=6_1_7601
Sec[6].Key=Service Pack
Sec[6].Value=1_0
Sec[7].Key=Product
Sec[7].Value=256_1
State[0].Key=Transport.DoneStage1
State[0].Value=1
State[1].Key=CA
State[1].Value=1
State[2].Key=BLOB
State[2].Value=CHKSUM=41E1B862E4FAB6C331493E72F473696D;BID=OCATAG;ID=105759b9-6c67-4aed-8d73-aa62f8273845;SUB=2//25//2013 1:43:52 PM
File[0].CabName=022513-12370-01.dmp
File[0].Path=022513-12370-01.dmp
File[0].Flags=851970
File[0].Type=2
File[0].Original.Path=C:\Windows\Minidump\022513-12370-01.dmp
File[1].CabName=sysdata.xml
File[1].Path=WER-31527-0.sysdata.xml
File[1].Flags=851970
File[1].Type=5
File[1].Original.Path=C:\Users\Kittencake\AppData\Local\Temp\WER-31527-0.sysdata.xml
File[2].CabName=WERInternalMetadata.xml
File[2].Path=WER88FD.tmp.WERInternalMetadata.xml
File[2].Flags=589827
File[2].Type=5
File[2].Original.Path=C:\Users\Kittencake\AppData\Local\Temp\WER88FD.tmp.WERInternalMetadata.xml
File[3].CabName=Report.cab
File[3].Path=Report.cab
File[3].Flags=196608
File[3].Type=7
File[3].Original.Path=Report.cab
FriendlyEventName=Shut down unexpectedly
ConsentKey=BlueScreen
AppName=Windows
AppPath=C:\Windows\System32\WerFault.exe
Version=1
ReportType=4
Consent=1
Response.type=4
UI[6]=&Check later
UI[7]=Cancel
UI[10]=Close
Sec[0].Key=BCCode
Sec[0].Value=124
Sec[1].Key=BCP1
Sec[2].Key=BCP2
Sec[3].Key=BCP3
Sec[4].Key=BCP4
Sec[6].Value=1_0
Sec[7].Key=Product
Sec[7].Value=256_1
State[0].Value=1
State[1].Key=CA
State[1].Value=1
State[2].Key=BLOB
File[0].Type=2
File[1].Type=5
File[2].Type=5
File[3].Type=7
AppName=Windows
