1 - 20 of 36 Posts
Originally Posted by Blackhawk4
......really?
There is a hobby for everything.
After the reading the thread the other day about razors, I finally pulled the trigger and got a DE. I bought a used Gillette SS. I recently ordered a sampler pack of blades at WCS, some proraso cream, and an Omega 31064. While looking around locally, I found a fruit bowl at Target that looks like it'd make a good bowl for lathering.
I've never shaved with a DE, but I'm a bit excited to try it out once the stuff gets here.
Discussion Starter #4
......really?
yes.
now back to the original subject.
my SD curently has a
Wapiencha str8
Gillette 1920's genuine
Feather DE blades
Derby DE blades
Super-max DE blades
Wilkinson sword DE blades
Wilkinson sword boar brush
Williams shave soap
Poraso white shave soap
Poraso pre-shave lotion
glycerin soap
Kaloderma shave cream
and Nutragerma post shave lotion
pics forthcoming
9 Cans of Ravioli
I don't see why people go through so much trouble with shaving. I get a close and comfortable shave with a cheap razor and generic shaving cream. If I'm shaving every day I don't even worry about lotion. If I go a few days, slap some generic lotion on my face and I'm good.
Never cut myself, razor burn only if I don't put lotion on my face after not shaving for a few days then shaving ... etc. And I have REALLY sensitive skin.
Oh well. Each their own. I like my disposable razors. $5 every three months.
I feel like you do.
I just use a Gillette mach 5 or w/e with nivea or Gillette shave cream.
9 Cans of Ravioli
Originally Posted by The Master Chief View Post
I feel like you do.
I used a Schick Quattro Titanium for a while until I lost it on Spring Break last year. I get as close of a shave with a pack of 9,000 disposable razors for $1 as I did with that, ... plus the refill blades are expensive.
It did look cooler, though
Discussion Starter #9
for most that's fine. but as said before for some its a hobby. we enjoy having "me" time and not having to rush through our morning routine. or its for people who can not get a good shave from the mass market stuff.
and here is what is in my shave den.
and now for some lulz
YouTube- 14 Rabbit Of Seville
Discussion Starter #10
and as for your acquisition of a SS make sure to cleen it good. like scrub the crap out of it then do a couple baths in bleach solution. make sure to let the razor dry in air between each bath. better to be safe than sorry.
I did all that the day that I got it. I kept reading about soapy bubbles stuff which I concluded was just bathroom type cleaner. I soaked it some of that stuff and it put stains all of the razor. That really got me upset. However, I continued with the cleaning process and threw it in some bleach as well.
Discussion Starter #12
yea mantic dosent recommend using the chemical cleaners due to possible plate damage and also irritation to your skin.
There is a hobby group for shaving?
uhhh...I shave like once every 2 or 3 months with a Gilette Mach 3 that Gilette sent me in the mail on my 18th Birthday. I am now 28, so I've been using it for 10 years. I just buy new razors for it every now and then. I also use Gilette shaving cream.
I guess you learn the hard way. Either way, I managed to get it looking good again. Here's a pic of my SS. Hopefully the package from WCS comes today or tomorrow.
Discussion Starter #16
nice SS man
and as for the cartrage users. i'd suggest getting a cheap brush and soap. i dont know if walmart still sells them but you can get a good starter kit from VDH for like $10 includes brush bowl and glycerin based shave soap.
heres the soap.
http://www.walmart.com/ip/Van-Der-Ha....5-oz/10322202
but a proper soap and a brush will yeild a much nicer smother moisturizing and protecting lather than what pressurized goo can. that and using a brush heplps exfoliate and lift the beard to give you a better shave.
I usually rub a dry Ghilette Fusion all over my face and change the blade once every 2 months... and I still don't break out
. I'm a blade-o-phile though and may try a straight razor. I enjoy stropping daily and resharpening my Benchmade Griptillian weekly. How difficult is shaving with a straight razor?
Discussion Starter #18
its not too dificult as long as you have a good lather and a good steady hand. the real hard part is the curves of your face *chin* and neck. the grip can be a bit tricky also.
but as for the actual dragging the razor across your face. as long as you have a good angle on the blade and dont move down the blade you should be fine... but pre shave prep is the main thing.
Nothing special here:
- Gillette Fusion razor
- Gillette Fusion HydraGel (Shaving Gel)
- Clarins Men Shave Ease Oil (I put this on before the shaving gel)
- Clinique post-shave healer
Merkur Barberpole Safety Razor
Derby DE blades for everyday, Feather for special occasions
The Art of Shaving Pure Badger Brush
"" Sandalwood Pre-shave Oil
"" Sandalwood Shaving Soap
Thinking about getting some Proraso and a good shaving mug.
1 - 20 of 36 Posts
