Got this CM case and CM AIO 240mm rad cooler.
I know the pump must be lower than the rad/res fro AIO.
Given the limitation of the small case, I decided to mount the rads on the side panel, however, should the I have the inlet/outlet tubes on the pump be on top or bottom?
