1 - 3 of 3 Posts
My 780 evga asx sc stock - boosting about 1097
My gtx 980 msi gaming stock - boosting about 1330-40
2fps upgrade ye!
Though ofcourse the 980s are amazing oc'ers, and my 780 only had 68% asic and could not oc any more than the stock without + voltage. While my 980 can easily oc to 1530 on stock volts with an asic of 78%.
980 +180 core + 220 mem boosting about 1530 stock voltage
Am I crazy for spending £440 on an incremental upgrade? The reason I upgraded though was that 780 was a lemon, it would crash and overheat and the fans are so damn loud.
your not crazy,just remember that the 900 series haven't got any decent drivers yet,,,,see how it looks in 2-3 months when they get the bugs worked out
Ye that's what I keep telling myself
Batman origins - 1440p max settings physx high / txxa high
780
980
4 fps difference
Is that not supposed to be the difference between a 780 and a 970, not a 980. Some foul play at work here, surely not holding it back. Afterburner reporting full usage, with a 4670k @ 4.4ghz and a evga g2 supernova 850W.
If this is the case I will just send it back and side grade to a 970 if they are both basicaly side grades anyway and save £150 that can be put elsewhere in my system.
1 - 3 of 3 Posts
