1 - 13 of 13 Posts
Here is the situation.
>Have a laptop
>Need to reinstall windows
>Cant boot from USB so i cant install from my thumb drive
>CD drive doesn't work
>Cant recover it (tried)
>Only solution is to pull the hard drive, attach to my desktop, install there.
>I need to know what adapter this is and i need a SATA>(???) cable so i can connect it to my desktop, i think its ata.
This is the same hard drive:
Amazon.com: 160GB 2.5 Inchs HDD Hard Disk Drive for HP Pavilion DV1000 DV1100 DV1500 DV5215US DV5224NR ZD7000 ZE1000 ZE2308WM ZE4100 ZE4400 ZE4500 ZE4600 ZE4700 ZE4800 ZE4900 ZE5155 ZE5170 ZE5185 ZE5200 ZE5300 ZE5400 ZE5500 ZE5600 ZE5700 ze2000 Laptops: Electronics Amazon.com: 160GB 2.5 Inchs HDD Hard Disk Drive for HP Pavilion DV1000 DV1100 DV1500 DV5215US DV5224NR ZD7000 ZE1000 ZE2308WM ZE4100 ZE4400 ZE4500 ZE4600 ZE4700 ZE4800 ZE4900 ZE5155 ZE5170 ZE5185 ZE5200 ZE5300 ZE5400 ZE5500 ZE5600 ZE5700 ze2000 Laptops: Electronics
And here are pictures i took:
I agree with the other posts in this thread.
But I'm not sure what good it'll do you? You can't really reinstall Windows from another computer... Windows setup is where it detects all the drivers for that specific computer. Brand new desktop to ancient laptop is unlikely to go smooth.
he can do the install to the point where it copies the files over though, then switch the drive back to the new machine and let the install complete in the laptop.
Hmm... I suppose. Creative, if it works.
It works with Server 03 - I can't believe it won't work with XP also as they're the same under the hood.
Oh, it definitely works in XP - but XP's install can really be mucked up if you so desire. It's possible to install onto a flashdrive, for example.
But since he didn't list the OS, we can only speculate.
Well, he has a laptop with a 160GB IDE drive in it - which makes it too old for Vista and too young for WinME - really XP is the only possibility.
I have seen Vista capable laptops running off PATA drives. Someone I know has a Turion X2 / 4GB DDR2 / Samsung 160GB 2.5" PATA laptop. I think it was an Altec Lansing.
The design decisions of some laptop makers...
1 - 13 of 13 Posts
