1 - 4 of 4 Posts
Filthy Casual
Hi guys,
I'm working in an ITAD / Repair capacity, and I have some motherboards from iMac A1418 and A1419 I'm trying to remove the heatsinks from, so I can determine the CPU model.
I've tried a couple random 6-point star heads I had lying around, nothing doing.
My Google-fu is also apparently terrible as far as this particular question goes.
The last thing I want to do is spend $10+ on a niche screwdriver that doesn't fit, and I won't have any other use for.
I would also like to avoid buying something like a full iFixIt kit or something else that's all-inclusive.
Just trying to find the one screwdriver...
Any help from you Apple Pros / repair junkies?
Thanks!
OCN is bad civilization
Filthy Casual
(un)Fortunately, the motherboards have already been removed from the cases.
I haven't been able to find any Logic Board numbers in the format google is providing, and I don't have original serial numbers.
Just a big ol' pile of motherboards...
They're running PC3L-12800 and Samsung m.2 drives.
There is a sticker down by the RAM cage thing, here's 2 examples from there:
CE3D 31PITMB00H0
CE3D 31PITMB00B0
But I'm not finding the Apple sticker with barcodes anywhere on this board.
Thanks for the advice so far, though!
OG AMD
My guess would be T8. Obviously T5 is smaller than T8 so maybe you can tell.
1 - 4 of 4 Posts
