1 - 5 of 5 Posts
Requirements:
- 16:9
- 27" or below
- 1440p
- 144Hz or better
- IPS or VA
- Preferably G-SYNC
- Strong preference for monitors with stands that are less than 22cm deep (any more than this leaves precious little room for the keyboard)
- Overwhelmingly strong preference for displays without backlight bleed
Thanks in advance!
Bends are for the weak
Requirements:
Thanks in advance!
Just two remarks: Get yourself a monitor stand instead of relying on manufacturer decisions. You will love it.
Also: IPS is virtually impossible to find without backlight bleed.
That said, there are two immediate, quite popular options:
https://www.asus.com/Monitors/ROG-SWIFT-PG279Q/
https://www.acer.com/ac/en/GB/content/predator-model/UM.HX1EE.005
There are alternatives:
http://us.aoc.com/product_feature.php?id=15
Basically, all three use the same panel and build their own bells and whistles around that.
I'm pretty sure I told you to make this thread in another thread.
As stated I love the Nexius EDG, I'll edit in a second and post my thread.
Here ya go
http://www.overclock.net/#/topics/1665593
I would also recommend you get your own stand if that's your only hang up on a monitor.
I intended to use the robot arm that came on my old HP monitor so I bought the cheaper version of my monitor while eBay was having a 15% off sale. $380 was a pretty good deal imo. No Gsync but it would be wasted on me.
FYI there are no 1440p IPS panels under 27", I was looking for almost exactly the same thing you are.
There's no such thing as one without bleed or glow but luckily my bleed is so minimal I don't notice it ever.
Keep in mind that nvidia is still asinine about blocking freesync/active sync/adaptive sync (whatever you call the DP sync standard) in their drivers, making that functionality essentially worthless for nvidia gpu users.
That's probably why he specified GSync.
1 - 5 of 5 Posts
