What are the best NIC chipsets?
410 Views 4 Replies 5 Participants Last post by  xXkeyboardkowboyXx
I'm throwing together a untangle router/pc and was wondering what would the best/most reliable NICs to install. Gigabyte is not neccessary.
Honestly I'm just learing about NIC chipsets. I've only heard broadcom and intel. Who's got the best.
1 - 5 of 5 Posts
Any major brand with goood driver support should be perfectly sufficent.
Intel, Marvell, Realtek...all good, with reliable, up to date drivers.
If I had to choose a best, I'd probably pick Intel, but the chances of you noticing a difference between any of them on a non-gigabit router are next to nil.
Realtek = Terrible brand.
Intel and Marvel are the best chipsets out there for NIC's.
Obviously can't have two good ones.
Originally Posted by CallmeRoth
Wouldn't this be a suitable application for that overpriced KillerK1.
Nope its never a good time to buy a killerk1
from what i hear if you buy an aftermarket NIC you just buy an intel pro NIC.
1 - 5 of 5 Posts
