What are the temp readings in speedfan
331 Views 4 Replies 2 Participants Last post by  brumby05
I just downloaded and opened up speedfan. The temps that are listed are:
Temp1: 45C
Temp2: 14C
Temp3:-2C
Core0: 21C
Core1: 22C
I know that the core 0 and 1 are my cpu temps. What are temp 1, 2, and 3?
1 - 5 of 5 Posts
Core 0 and Core 1 are the 2 cores in the CPU
Temp 3 is a bogus sensor
Temp1 could very well be your chipset temp.
Temp 2 i dont know
I just checked everest also, which gave me about the same temps. I guess that temp 1 is my case temp (in everest, the temp that matched temp 1 was called aux, I assume aux is my case?). And I think temp 2 is my mobo. Thanks
Your chipset is running at 14C, have you got a custom cooler on it?
Temp 1 will not be your case temp.
you would never acheive 14C chipset with a case of 45C
Although i'm not sure what the aux is
In everest, it says that my mobo is at 18C. Ambient temp is at 23C.
Oops, my BT fan was not on, now mobo temp is at 16C with fan on. Whatever
1 - 5 of 5 Posts
