1 - 3 of 3 Posts
Here is the answer I found on Reddit for you, from a user called Mhhkb:
Note that some models require you to pay attention to what revision you already have. The 3070 Aorus Master, for example, offers two vBIOS updates. One is F2. One is F62. It states that you can only upgrade within the same range, so if your card is F1, get F2. If it's F60, then do F62.
If you can't figure out what you have, fire up GPUz, go to the advanced tab, Click the drop down and choose NVIDIA BIOS. You'll see your revision under the "Message" field. In my case, GV-N3070AORUS M-8GD/F60/0B36.
I bolded the F60. That tells me I need the F62 vBIOS.
Source: https://www.reddit.com/r/gigabyte/comments/mgg17h
Reactions: Gil80
1 - 3 of 3 Posts
