OH GOD NO!!! lol
coolant coloring
more pretty colors!
colored additives - highly recommended!
even more choices! - the little fasteners are just above the colors too...
and for the clamps, get the ones that you tighten w/ a screw (not sure the exact name lol) but get around 14mm for 1/2" i think it is... you want it a little larger than the size of the tubing so you can slide it over the fittings.... but not too large or it wont be able to tighten down as well...
good luck
coolant coloring
more pretty colors!
good luck
