Okay, so I've been out of the GPU loop for a while. I'm going to be getting my 939 rig back up and running again hopefully. So what GPU should I go with? It will be on my main rig at first (not my sig.....the specs below), and then it will be retired into my HTPC build for HTPC / gaming on the TV use....again, specs below.
Main Rig Specs:
Opteron 165 @ 3.0GHz (in the future, if I can buy it back)
4GB Corsair XMS DDR400
A8N32-SLI Deluxe
Antec TruPower Trio 650w
Dell 17" CRT Monitor (for now, going to get a 26-28" LCD later)
HTPC Rig Specs:
Athlon X2 3800+ Manny @ 2.4GHz
2GB mixed DDR400 (4x512MB)
Jetway 939GT-4 SLI
Apevia 500w PSU (came in X-Master case)
1080p TV in the future, 540p TV for now or the 17" CRT
As you can see, it must be a somewhat low power card, so I don't kill the Apevia PSU. It also can't run too terribly hot considering it'll be going into an HTPC case with VERY little air circulation. But I would really like it to be as powerful or more powerful than an 8800GT. So suggestions?
Main Rig Specs:
A8N32-SLI Deluxe
HTPC Rig Specs:
Jetway 939GT-4 SLI
