What cooler should I get for my 5770?
455 Views 7 Replies 4 Participants Last post by  Lord Xeb
I just contacted ASUS today (RMA stuff) and they are looking for a new card to replace my V1 5770. As of right now, it seems they are out of stock of the 5770 V1s so I told them to get me a V2.
What cooler would fit on the 5770 and perform well? The Mushashi is "fits" after some tinkering.
1 - 8 of 8 Posts
Anyone?
I have a Zalman VF1000 with all the original packaging and accessories if you are interested.
Um.... the mushashi does not fit. The 2 DVI stacked on top of each other are too tall and the mushashi heat pipes hit the back plate.
Oh, I thought you said it "fits" with tinkering..
Why do you want an aftermarket cooler? The stock one is pretty good.
That tinkering also broke a heat pipe. Also the new HD5770 I am getting has the V2 cooler on it which sucks ass!!!! If I can find a V1 cooler, I would use that instead.
1 - 8 of 8 Posts
