1 - 20 of 39 Posts
I purchased a new computer some months back and thought I ordered a 955BE. I noticed that the BE does not show up on the CPU-z checks of other peoples machines. (OR mine)
Is the only way to tell by trying to raise the multiplier? Mine goes down not up. Or do I have to enable this function in Bios?
Kevin
Post a screenshot of cpu z or validate it and post a link.
looks like u have a aftermarket board. Cool N Quiet is on and also ur multipler for ur FSB is 16. If u go into Bios (hit Delete when ur computer first comes on) and select MB Intelligent Tweaker (M.I.T) and go to CPU Clock Ratio. It will be on auto. Select it and go down to the bottom. If u have options beyond 16x it is a BE cpu. I could be wrong but I don't think they made a Non BE 955.
Discussion Starter · #8 ·
Great, but why do the multipliers not go up??? I cannot gt them past 16 as the sliders are all the way up. I am using AMD Overdrive along with CCC for the XFX5850. I have tried some of the other software, MSI Afterburner and such but non of the make any difference.
Suggestions??
Kevin
Suggestions??
Kevin
You have to overclock in the BIOS. Typically software overclocks are unstable.
Discussion Starter · #14 ·
I have read the stickies in multiple forums on overclocking and tweaking before I attempted to try. I have not read anywhere that you have to go into the Bios to do it. Shouldn't that be the first thing a newbie is told??? It is not for lack of reading that I am ignorant, just lack of finding the right info. I have tried to tweak what I ask in the search engines but I always come up with the same info.
Now another question, you fellows talk a whole bunch about cooling. None of you or anyone else on other forums seems to agree what is to much heat. I have a liquid cooled stock system. What can I expect and please, what is a safe limit for a knothead to use?
Discussion Starter · #16 ·
Thanks, I did do it in Bios and just upping it to 17 and optimizing voltages in there gave and increase in Furmark of 4000 points. I will have fun learning more and checking out the temps and such now. You guys have made my day! Thank you very much.
Kevin
Kevin
Did you turn off cool 'n' quiet and the other power saving features?
1 - 20 of 39 Posts
