1 - 11 of 11 Posts
Case: Gigabyte 3d Aurora (newegg.com) $160
PSU: Antec NeoHE 550W SLI Modular (securemart.com) $107
Water Cooling: Gigabyte water cooling (newegg.com $150
Mobo: Gigabyte 975X PCIe SLI LGA775 (www.mwave.com) $250
Processor: P4 630 3.0Ghz 64bit 2MB L2 (www.newegg.com) $174
VideoCard: XFX 6800 GS XXX (www.zipzoomfly.com) $205
RAM: Transcend DDR2-533 1GB (www.newegg.com) $80
HardDrive: WD Raptor 74GB (www.pcconnection.com) $209
Disk Drive: Gigabyte CD-RW/DVD-ROM (www.newegg.com) $35
TOTAL: 1362.11 (my max is 1400.00)
Everything is retail. I am open to suggestions. I am selling my current one for about $800 (heh to a nooblet)
I have a Raptor now, I am barely using 10GB. I have never used more than 20GB. I am stingy, I delete everything I can.
When I get the money I will upgrade to another Raptor and RAID 0.
the raptor is on newegg right now for 150 ish, yesterday it was 136 with rebate. I guess u just missed out. U can still save 50 bucks and spend it on ram.
Discussion Starter #5
I just bought one of those $136 Raptors for my old rig. I wanted all retail stuff on this one (for the warrenties and such). So I had to get the more expensive one.
humm.... i dont like that watercooling!!
if you want to choose that one i will go with a si-120 which will be about the same @ $65
and the video card i would go with a 7800 gt and X1800xl those are about $300 right now and if you go aircooling you would have more to spend on the video card. i think even x840 is around $250
Power Squid
I'd get a DVDRW instead of a combo and why are you downgrading the CPU? Unless you intend to put the new 630 in your old rig and keep your current 650.
Discussion Starter #10
Im going from a 3.4Ghz 32bit 1MBL2 to 3.0 GHz 64bit 2MB L2! That no downgrade because the 630 will easily OC to 4Ghz+ with the water cooling.
Discussion Starter #11
Noted. I will stick with one raptor for now, because that is a very easy upgrade in the future. I may go for one of those 7800GTs on newegg.com for $290.
1 - 11 of 11 Posts
