What do you think of the "Creative Inspire T7700" speaker system?
  • It's Awsome!
    Votes: 0 0.0%
  • Pretty Good
    Votes: 0 0.0%
  • Maybe
    Votes: 0 0.0%
  • Not worth my green
    Votes: 0 0.0%
  • It's crap!
    Votes: 0 0.0%
1 - 2 of 2 Posts
This is just a thread to gather your input on the Creative Inspire T7700 speaker system or, perhaps, better systems.
Here's the specs:
SPECIFICATIONS
Feature Description Satellite Speakers Speaker Power 8 Watts RMS per channel (6 channels)
20 Watts RMS center speaker
24 Watts RMS subwoofer Audio Specifications Frequency Response 40Hz ~ 20kHz Physical Dimension (L x W x H) Satellite Speaker
9.5cm x 7.7cm x 16.8cm (with tweeter)
9.5cm x 7.7cm x 14.0cm
Subwoofer
19.2cm x 30.0cm x 28.3cm
Audio Control Pod
4.7cm x 2.5cm x 10.4cm Others Signal-to-Noise Ratio (SNR) 80dB
I think they are a good value speaker. Obviously there are better more expensive systems out there. I have the inspire T5400 which is very close in specs minus the extra speakers for 7.1 I am very pleased with them. I live in an appartment so I did not need nore could I use a realy high output speaker system anyway.
I have not had any problmes with the system and it installed and runs perfectly. The base response is good and the mid and highs are well executed.
I think it is a great system to go with.
1 - 2 of 2 Posts
